Old 06-14-2020, 07:48 AM   #1
Dometic 9100 (powered) outer channel replacement
The (left side) outside channel on our Dometic 9100 power awning got bent and I found a replacement for just the channel. The top bolt and two lower pins will have to be removed, but NOT the entire arm assembly. Can someone give me pointers/cautions regarding the procedure?
(i.e. awning extended or retracted, pinning the torsion spring if necessary, etc.)
Thanks in advance.
JerryMcD is offline   Reply With Quote
dometic, power, replacement
