I might have one. I have a scrapped 9200 bracket set that recently had a bad day.
I'll look tomorrow and verify if no damage. Few bits survived.
Other than color, I believe all brackets for 9200 are now the same. All are drilled for basement or top power. .
My experience with Dometic has been nothing short of a disaster.
Installed new bracket kit and found the motor defective. Not a huge thing....if they actually could supply one. They cannot. Back ordered. Gads.
While not fun in 95* weather, it's easy to do.
Included the bracket part number. Should match yours.
You probably are aware, but be sure to strap the gas cylinders by strappingthe arms or whatever will prevent extension if you remove any bracket pivot point. There's no rewind spring, as in a 9100, but those cylinders will extend the brackets aggressively. Be careful.
You can see the straps on the brackets at the top. Strap both arms, or extend and place supports beneath the roller. It will not try to retract.
