Old 06-19-2020, 09:25 AM   #1
dometic Awning wiring
I own a 2020 Forest River EVO 267ss TT. Awing works intermittently. Think maybe a loose connection or something I removed switch from wall. You can see wiring in attached photo. the black and red wires go to awing motor. The yellow is the 12v from fuse panel. Does any body know what the white wires are for?
I get 12 v on both yellow wires, when switch is moved to one of the on positions I get 12v at either the red or black wires. seems the switch is working properly. I disconnected wires going to motor near the motor. I hooked up wiring straight from battery to motor side connection. Awing works in both directions when wires are switched at battery. so that tells me motor is okay. I then hooks up wires from switch direct to motor, bypassing TT wiring. awing won't work. If I remove black or red wire, from motor connection and ground it motor works. I ground it to door frame. This has me puzzled.
trying to figure this out. Just did another check. Using OHMS setting on meter, no continuity from white wires to ground, using door frame as a ground. switching meter to dc volts I get 12 v at yellow wire and either red or black wire using door frame as ground. If I switch ground lead to white wires I get 3.6v. Maybe the white wires are a ground for the switch and maybe a bad connection to ground? I can't see where white wires go due to them being inside wall.
Name:	awing switch.jpg
hoop1252 is offline   Reply With Quote
Old 06-19-2020, 10:05 AM   #2
Your assumptions are correct.
The white wires appear to be the ground circuit. (for either direction of the motor)
I would follow them and see if the connection to ground is compromised.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 06-19-2020, 10:37 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
If it is like my awning it had a loose connection in the awning roller assembly hard to get to dealer fixed under warranty. Later RJD .
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 24
Old 06-19-2020, 04:28 PM   #4
Couldn't figure out where the white wires went to, wasn't going to pull off wall boards, so I found another place to create a ground and run new wires to switch. work okay now.
dometic, wiring
