Old 03-13-2018, 08:22 PM   #1
Entrance Door
Just purchased a Sabre from Forest River and the door will not stay shut. We have slammed it shut only to look in the rear view mirror to see it has opened again. We have made sure the stairs are locked in the screen door is closed, nothing keeping it from latching. We even lock it and it will pop open. Help!!!!
wdrichar is offline   Reply With Quote
Old 03-13-2018, 09:07 PM   #2
Locky's Avatar
Sounds like an alignment issue. On your door frame you have whats called a strike that your latch locks behind when the door is shut. You should be able to loosen strike and slide it slightly forward then tighten it back up again. If this is it then it's a 30 second fix. Keep us informed.
2018 Rockwood 2906WS
2013 Chevy Silverado
1967 Beautiful Wife
Locky is offline   Reply With Quote
Old 03-14-2018, 08:27 AM   #3
Thank you! Will let you know
Old 03-14-2018, 08:37 AM   #4
Kanadian Kamper
kenandterry's Avatar
Trailer or motorhome.....once underway....both doors locked for security.
Regular lock and dead bolt. This way if one fails to latch, the other might keep it closed.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 03-14-2018, 08:40 AM   #5
Kaadk's Avatar
If you have one of those big D handles, you can swing it over the door as well.
door
