You can try bigger diameter screws but if that doesn't feel secure enough, fill the holes with a two-part epoxy and re-drill the holes to fit the original screws. Just remember to use a drill bit one size smaller than the screw shank. If the original screws are screwed into wood, still use the epoxy , if they are into an aluminum stud, bigger diameter screws should do the trick with the epoxy as an added holding power. Best of luck and let us know how you make out.
Always remember, hills are only speed bumps on a bigger scale!
2013 Sabre 34 REQS-6 pushing a 2016 GMC Sierra 6.0L 2500HD
