Old 05-04-2020, 03:47 PM   #1
SJB
Smile Forest River 2608BS Door Slams Shut in Wind
We have a Forest River 2608BS TT. The entrance doors are supposed to stay open when fully opened toward the side of the trailer. However, with even a slight wind, the door slams shut.
Have any of you found a way to secure the entrance door in the open position?
Thanks for your input.
P.S. I love the trailer but not the door slamming.
SJB
2020 Rockwood 2608BS
SJB is offline   Reply With Quote
Old 05-04-2020, 03:56 PM   #2
bikendan's Avatar
Probably has loose friction hinges.
If it's still under warranty, you need to have it looked at.
Equalizer WDH
Old 05-05-2020, 10:37 PM   #3
jay2703's Avatar
Our 2304S door has a gas shock on it to hold it open.
2011 Rockwood Mini Lite 1809S
2013 Rockwood Ultra Lite 2304S
2004 Dodge Dakota SLT+ 4.7
2012 Ford F150 FX4 3.5 EcoBoost
jay2703 is offline   Reply With Quote
Old 05-06-2020, 02:37 AM   #4
Member: Old Man Club
RockDodger's Avatar
You could always install a door retainer latch. they make them out of metal or plastic and the work great. Very easy to install, relatively inexpensive, and available at most camper stores like CW, or hardware stores, and Amazon of course.
"Walk softly...and carry a lot of tools!"
2016 Ford F250 Super Duty Crew Cab, 4x4
2021 Palomino Puma 27RLSS
RockDodger is offline   Reply With Quote
Old 05-06-2020, 03:57 AM   #5
bikendan's Avatar
Many newer trailers have friction hinges, thus eliminating the gas shock.
Equalizer WDH
Old 05-06-2020, 03:31 PM   #6
ours 2020 2608BS does the same ! is there a way to tighten the hinge without taking it back to the dealer?
Noahron3 is offline   Reply With Quote
Old 05-06-2020, 03:50 PM   #7
We have a 2018 Rockwood 2608SB model in New Zealand and have experienced the same issue. I am not sure that this would be an issue only on this model, as these doors would surely be massed produced for several models rather than one specific model. However, I did read elsewhere in the forum, that the anti slam doors are rated to withstand only a 20mph wind. So, maybe not a sudden gust.
Static 2018 Rockwood 2608SB
happychappie is offline   Reply With Quote
Old 05-06-2020, 04:00 PM   #8
SJB
Our door is blowing shut in winds much lighter than 20 mph.
Does anyone know if there is a way for us to adjust the friction in the door hinges ourselves without taking it to a dealer?
SJB
Old 05-06-2020, 05:11 PM   #9
FOLLOWING
I've heard this is a common failing as the doors age. Mine works well now, but knowing if there's an adjustment will surely be handy someday.
And...my awning struts prevent to door from opening more than about 90 degrees when the awning is out, so, short of anchoring it to the awning frame, I think this hinge is going to HAVE to work.
Watching with anticipation.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 05-06-2020, 05:35 PM   #10
SJB
Originally Posted by jimmoore13 View Post
FOLLOWING
Thanks but...Our trailer is less than a year old so I hope nothing in it is aged yet (especially since with this Covid situation, it has only been used about 10 times!
Hoping that someone out there can help us figure out how to solve the problem ourselves since taking it back to the dealer in Indiana isn't an option right now.
SJB
Old 05-06-2020, 05:38 PM   #11
bikendan's Avatar
You can use an independent RV shop or mobile RV technician. You just have to get pre-approval from FR and be willing to be reimbursed.
Equalizer WDH
Old 05-06-2020, 06:17 PM   #12
We have a 2015 2608, Same problem. The latches suggested in post #4 will work if you remove the gas strut. The space between the door and the side of the rv is too wide to use them. we've tried several.
In desperation I slit a piece of heavy plastic tubing length-wise and put it over the strut rod between the barrel of the strut and the door. If it's really windy I put a small ziptie at each end of the tubing. It's ugly and cumbersome but it keeps the door open. I'm hoping for a better solution as well.
Terry2608 is offline   Reply With Quote
Old 05-06-2020, 06:40 PM   #13
brookstone345sa's Avatar
brookstone345sa is offline   Reply With Quote
Old 05-06-2020, 07:51 PM   #14
Villagerjjm's Avatar
I would consider utilizing a stainless steel eye bolt that a bungee strap can hold onto. The bungee strap could be secured to the outside of the trailer. The eye bolt would have to go all the way through the door.
Villagerjjm is offline   Reply With Quote
Old 05-06-2020, 08:00 PM   #15
jeff64's Avatar
The plastic Ts are available in 6" size. Removing the gas struts was one of the first mods I did. I used one of each. My aft door clears a tilt out window open and doesn't make contact. It's all in where you place the components
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
jeff64 is online now   Reply With Quote
Old 05-10-2020, 03:35 PM   #16
SJB
Door Fix for Rockwood 2608BS
Here is my husbandís step-by-step fix for our door problem.
1. Open a standard 12-ounce beer can and remove pull tab.
2. Remove sheet-metal screw from bottom side of door frame. Replace screw so as to anchor a bent beer can pull tab. (May need thin washer on top.) See picture.
3. Use 18-inch bungee cord to hook into pull tab on one end (as shown) and under the side of trailer on the other.
4. Drink beer and celebrate the door staying open.
SJB
Old 05-10-2020, 05:26 PM   #17
Hatchdog's Avatar
^^^^^Best fix ever. And even a reward when your 2 minute fix is completed.
2020 Rockwood Ultra-lite 2608BS TT
2011 F250 Lariat 6.2 gas 6 sp auto 3.73 rear 4X4 6.75í bed crew cab
Recurve R6 hitch
Hatchdog is offline   Reply With Quote
Old 05-10-2020, 05:31 PM   #18
I believe that with the beer tab fix you have added some preventative maintenance that needs to be done. I would personally replace that beer tab on every outing to make sure it does not break.
BarabooBob is offline   Reply With Quote
Old 05-10-2020, 06:08 PM   #19
+1.
door, forest river
