Old 06-18-2021, 01:27 PM   #1
ARLO
Front stationary window leak
we developed a slight leak in the left rear corner of our front window. Would eternabond be a viable option to seal it?
rlocicero is offline   Reply With Quote
Old 06-18-2021, 01:34 PM   #2
Part-Time Campground Host
cboss's Avatar
What model camper do you have?
Craig & Cath
Days camped since 2015(retirement): 1282
cboss is online now   Reply With Quote
Old 06-18-2021, 01:36 PM   #3
Kanadian Kamper
kenandterry's Avatar
Confused where your trouble is……
“….a slight leak in the left REAR corner of our FRONT window.”
Silicone caulking might be better suited.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is online now   Reply With Quote
Old 10-15-2021, 11:24 AM   #4
How to caulk 2021 front frameless window
Hi
I was looking to see how to check/re-caulk my front window on 2205S but not seeing a way to do so from outside since these are in-set into the frame so looking for suggestions.
Chevrolet Silverado 2021 Crew LT 5.3 MaxTrailer
MiniLite 2021 2205S
Bigdaddyo is offline   Reply With Quote
Old 10-15-2021, 11:34 AM   #5
Originally Posted by Bigdaddyo View Post
Hi
You have a style that is set in urethane much like an automotive windshield. If it were to start leaking it would have to be cut out from the urethane, cleaned and reinstalled.
2020 2608bs Rockwood
2008 F250 Diesel
Fastway E2 12k square bar
Hayes Electronic Sway Master
Level Mate Pro
quinndav is offline   Reply With Quote
Old 08-19-2022, 12:31 PM   #6
Fixed Window Leak
I have a leak in a fixed window on my 2012 Sandpiper 356RL. The brand of the window is "Kinro". I have not yet been able to isolate the specific area that is leaking, but we do get water intrusion into the window sill (i.e. a drainless trough at the inside bottom of the window). Assuming I finally trace the source of the leak to the outside rubber trim, I am wondering if I should caulk beneath it, or is there a recommended alternative procedure I should follow?
wilfb100 is offline   Reply With Quote
leak, window
