Old 12-09-2019, 04:48 AM   #81
Indy500's Avatar
I
Originally Posted by jsalty View Post
I too would like to know if you replace extended or retracted
I did it while open
Indy500 is offline   Reply With Quote
Old 12-09-2019, 08:47 AM   #82
Originally Posted by Indy500 View Post
I I did it while open
Replaced mine while ipen. Rested awning on high step ladder and only discone ted motor side from arm.Be sure to put pin in opposite side to stop spring from unwinding. Google it, many you tube instructions on replacement.
2014 Cardinal 3450RL
2012 Ram 3500 DRW Quad Cab 4x4
nites traveled
2014 196
2015 146
2016 101
Haul-a-Fifth is offline   Reply With Quote
Old 12-09-2019, 08:48 AM   #83
Again, make sure to bench test your motor before spending any money. My awning did the same thing twice. Both times I took the motor out of the tube and connected it to a battery on the work bench. Both times it turned. I reinstalled it in the tube and it worked. I thought that something got out of alignment or jammed. But anyway, both times, just the R&R got it to work and it is still working. It is troubling that this has happened two times but it only cost me two pop rivets to reattach the end cap on the roller.
markb422 is offline   Reply With Quote
Old 12-09-2019, 09:19 AM   #84
Indy500's Avatar
Yours is not the same model has mine , on mine the spring is at the opposite end of the motor. Motor is on the end where wires are ,spring end has no wires. Mine clicked when button was pushed , but that's all it did. There is a sticky in the forum on mine
Old 03-23-2021, 04:06 PM   #85
Is this the type of awning motor that's replaceable with a cheap automotive window motor? Mine works, but is sluggish. If the motor is cheap, I'd like to keep one on hand in case it fails at an inconvenient time or place.
Can something in the awning be lubricated to make it work better, other than the hinge points of the arms? I already did that with little improvement.
ThanksClick image for larger version
ID:	250313Click image for larger version
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, 57 YTD 8/18, EOY est., 90+
chriscowles is offline   Reply With Quote
Old 03-26-2021, 10:50 AM   #86
Question Dometic 9100 motor assembly
Another question relative to the Dometic 9100 awning motor. Is the bracket on the motor end (where the wires exit from the motor) replaceable? This bracket attaches the motor "shaft" to the awning arm and has fractured as a result of arm failure in heavy wind. Motor shaft is presently tie-wrapped to the outside wall bracket on top of the arm mount assembly. Need to know if I need to replace entire motor assembly (motor is still good).
DRiveWell is offline   Reply With Quote
dometic, replacement, awning
