Old 10-19-2021, 05:18 AM   #1
Heavy Condensation
FR Rockwood 2020 2511S Mini Lite. In CT. visiting relatives. Been in the low to mid 40's at night.Propane heater set around 65-68, comes on for 3-8 minutes every couple of hours. Comfortable.
My question is this, woke up this morning with heavy (I think) condensation on the inside of my fixed front window.Front of TT over head of bed. 6 other windows throughout TT have no condensation. All were shut tight for the night.
Should I be concerned about this? Let it air dry and then clean? First morning we've noticed this. Temperature differential of outside inside glass?
Thoughts?
2020 Rockwood 2511S MiniLite
2018 RAM 2500 Crew Cab 6' bed 4X4 6.7L Cummins Diesel Turbo 6 Speed Rear Posi Traction
'We may never pass this way again'
2021 Days Camping 184
2022 Days Camping 126
2023 Days Camping 128
TwoKozy is offline   Reply With Quote
Old 10-19-2021, 06:47 AM   #2
Thoughts?
I assume you slept in the area where the condensation is?
Simply air out the camper once the outside temps get into the 60's. A fan to increase circulation can help.
If you are going to spend more nights I'd crack a window a bit to promote air exchange.
Tow vehicle 2021 F-250
TT Apex 256BHS
Tabasco_Joe is offline   Reply With Quote
Old 10-19-2021, 06:56 AM   #3
Chuck_S's Avatar
Nomenclature matters.
You really using a propane heater?
A propane heater puts out quarts of water vapor and CO2 at best (CO at worst) -- use your furnace instead as all the vapor and fumes go outdoors.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 10-19-2021, 07:24 AM   #4
Flybob's Avatar
I would be worried if you did not have some condensation on the window as that is the result of breathing. As counter intuitive as it sounds, crack a window or two in the bedroom to allow for some outside air. You can also add a small fan to circulate bedroom air with living area. Also check the mattress for moisture anywhere it is against an exterior wall. If needed add a foam swimming pool noodle between wall and mattress.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-19-2021, 07:27 AM   #5
-- Chuck
You do realize all that water vapor and carbon monoxide get vented outside when running the camper's propane heater?
His condensation is caused by their breathing as someone above posted.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is online now   Reply With Quote
Old 10-19-2021, 07:32 AM   #6
-- Chuck
The furnace is a propane heater isn't it ? I think the op means furnace .
MR.M is offline   Reply With Quote
Old 10-19-2021, 08:13 AM   #7
Woke this morning in PA with some condensation on the windows. Same as above, utilized the furnace. We started a very small dehumidifier and the windows cleared off. To the question above, should we have wiped down the windows?
SK ON THE ROAD is offline   Reply With Quote
Old 10-19-2021, 11:36 AM   #8
By comparsion, we were camped in our Spirit 1943RB last week, since having shore power used out electric tower heater to keep warm, water heated on Electric as well.
We had minimal condensation on the windows in the morning, more on the kitchen window with the coffee maker nearby. As noted, propane heating does put some moisture in the air. One way to mitigate it some is to crack open a roof vent, and have a small fan move air.
For us last week, once we wiped the condensation after opening the shades, it was pretty much gone the rest of each day.
Rolland is offline   Reply With Quote
Old 10-21-2021, 09:40 AM   #9
Crack open the roof vents about an inch and that will reduce your condensation.
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2022 Ford F-350 Lariat, 4x4, CC, SRW, 7.3L
01tundra is offline   Reply With Quote
