Old 05-21-2013, 12:21 PM   #1
Helmsey's Avatar
Help with repairing crack around window
hile cleaning the camper I noticed what appeared to be a crack in my gelcoat around the top of the rear window. I couldnt get a good look at it so after dragging the ladder over and checking it out, it appears it's maybe a little worse than a crack.
Could I get some advice\suggestions for what I should do with this? My initial thought is to fill it with something to seal it, just not sure what.
Any ideas are appreciated.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 06-14-2013, 06:07 PM   #2
Thurman's Avatar
You're not going to like this but: IMO you will have to remove that window so you can tell just how much damage you have. As far as reinforcing it structurally, I don't know of any way you can. I have this type outer covering on my unit and there are two (2) cracks below the slide-out. I've been told by people who know that there is no way to repair these cracks. But--an older friend of mine made cabinets for years and he has looked at this. He believes, and I'm going to let him try, that he can place Formica over a large area which will also contain the cracks. He uses a heat gun to warm up the Formica so both of the materials are warmed before putting the glue on. I have nothing to lose and I trust him. Report coming later.
Thurman is offline   Reply With Quote
