Installing Lippert Solid step, 2014 Rockwood Signature Ultra Lite 8311SS
Hi everyone,
I need some help finding wires to the awnings.
I drilled though holes to install the new solid steps and drilled into a 4 wire molded cable that operates the awnings.
The cable runs just behind the door sill are 1 Black, 1 Red, and 2 whites, but I can’t find the path where the cable runs through wall to the control panel.
I was going to pull the new 4 wire harness I made from my front storage compartment but I just can’t find the damaged harness once it leaves the back of the control panel.
I see the cable behind the microwave and the WFCO8900 converter, but when I tug the cable, the wires I disconnected from the switch don’t move.
Thanks for any help you might give.
