Old 06-15-2020, 07:50 PM   #1
RGrimm's Avatar
Main door Friction Hinge
While some may like the new “friction hinge” main doors .... I hate it.
I have a 2021 Vibe 21BH with one of these doors.
Is there any way to eliminate the friction? Reduce it?
Thanks,
Russ
Russ & Arlene
Yulee, FL
2021 Vibe 21BH
2019 F150 3.5 Twin Turbo EcoBoost
w/ towing and payload packages
RGrimm is offline   Reply With Quote
Old 06-20-2020, 09:29 AM   #2
From some of the posts I have read on this type of hinge. It sounds like with use, open and close, wind opening and closing, it will loosen it up on it own.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 06-20-2020, 09:52 AM   #3
cboss's Avatar
With use ours got so loose I installed an old fashion door holder. The holder also won't let it slam shut in a wind.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 837
cboss is offline   Reply With Quote
Old 06-20-2020, 10:06 AM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
True, the friction completely wears off after 6 months or so.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-20-2020, 10:20 AM   #5
This Friction Hinge would NOT work along the East coast of the USA or the Gulf of Mexico! They do Help with "Door Slammer People" somewhat! We installed a Old Fashion T-bar stop! Youroo!!
Old 06-20-2020, 10:32 AM   #6
RGrimm's Avatar
I hope mine starts to free up sooner than later. I seems to cause a bit if stress on the door hinge wall. I guess for me its and age thing. I've had 3 RVs before this Vibe and all had 'normal' doors and two with latches like Cboss posted.
I had seen some posts when I Googled it on older (2018) and different brands that used 4 set screws in each hinge, those those were adjustable. You could loosen/eliminate the friction or even tighten/add friction. My doors appears to have steel pins pressed into the aluminum upper and lower hinges, not adjustable at all.
Thanks everyone for your comments.
Russ
Russ & Arlene
Yulee, FL
2021 Vibe 21BH
Old 06-20-2020, 10:52 AM   #7
I sprayed hinges with silicone spray and it helped as mine was doing same thing.
Gmoney67 is offline   Reply With Quote
door
