Old 05-15-2020, 06:05 PM   #1
pmurph991's Avatar
Question Older awning issue
I picked up a used A&E Dometic awning and want to install it on my 1999 Sandpiper. From all the YouTube videos I have checked out, they all say to count the number of turns when removing the tension to know how many turns to wind it when I install it. Unfortunately since there is zero tension, I am not sure how many turns to do before I go to install it. Any suggestion would be appreciated.
1999 Forest River - Sandpiper
pmurph991 is offline   Reply With Quote
Old 05-15-2020, 06:45 PM   #2
AudiDudi's Avatar
I helped replace an awning fabric about 4 yrs ago. As I recall, it was about 11 turns. The voice of experience says make sure to wind the tension in the correct direction. I think the direction is labeled on the end caps.
If the awning is rolled up now, as far as I know, unrolling it will put tension on it.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 05-15-2020, 07:44 PM   #3
Just as confused as you
Scrapper's Avatar
You are correct but you want tension on it when it is rolled up also. The number of turns will depend on the length of the awning plus 6 more turns.
Remember, on a manual awning each end has a spring that winds in opposite directions. An electric awning has only one spring at the end opposite of the motor.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 05-15-2020, 08:01 PM   #4
Scrapper's Avatar
Here's a document that will help you in getting the tension right. See TORSION ASSEMBLY TORQUE SPECIFICATIONS on page #6.
Richard & Jill
Old 05-15-2020, 08:49 PM   #5
pmurph991's Avatar
Solution found - Thanks All
I will just give it 6 turns before installing it.
Thank You Everyone!!!
awning
