One awning inoperative - 2012 Georgetown 373DS -
The forward awning will not function. Rear works OK. There is no power at the rocker switch, yet there is power to the rear rocker switch. The battery control box schematic indicates one of the circuits is for the awning(s) but removing that (good) fuse does not stop power to the rear awning. The main coach fuse panel (that also has all the 110vac breakers) does not have a fuse for the awning(s). None of the in-line fuses at the house batteries are associated. Nor are the fuses under the steering wheel, which requires a contortionist.
Any idea where I might locate the fuse for the forward awning? (...Or the rear one as well, so should that ever become an issue...).
-Richard
