Old 06-05-2019, 10:18 AM   #21
Wolverine 1945's Avatar
What does it cost to change Awning Fabric ???
Wolverine 1945 is offline   Reply With Quote
Old 06-05-2019, 11:14 AM   #22
NMWildcat's Avatar
The fabric itself is an average cost of $170. Range is $100 (sale) to $225 for an 18' awning. I have done it myself (with a helper) and it's not that bad.
If you hire it out, it's whatever they charge hourly, and I would think it would be an hour. Hourly cost around here is $75 to $150 per hour.
So do it yourself for around a $170, have someone else do it for twice that, is my estimate.
Scott and Liz - Southern NM
Old 06-05-2019, 08:50 PM   #23
I use bleach on my awnings every spring. Spray on undiluted, rinse off in a couple of minutes. Also a pressure spray, on lowest pressure, dose good job.
Had unit for 5 years, awnings still in good shape.
Garnie is offline   Reply With Quote
Old 06-13-2019, 06:29 PM   #24
rsdata's Avatar
Home Depot Mold Armor 2X...
this works better then any other mold spray that I have used, ( and that is quite a few) even on old black mold stains...
read my report here... especially post #2
http://www.forestriverforums.com/for...ot-134959.html
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 06-13-2019, 07:27 PM   #25
I have had very good results on mold with Krud Kutter...
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 06-13-2019, 09:35 PM   #26
Try Awesome, Dollar General.
retcsm is offline   Reply With Quote
Old 06-14-2019, 07:37 AM   #27
Don't get your mixture on the side of your unit !!!
Old 06-14-2019, 08:12 AM   #28
Finster's Avatar
Ive had good luck with bleach too. I dont use it full strength though, I dilute it 50/50 with water in a garden sprayer. I spray the under side of the awning, roll it up and wait an hour or two. Then I unroll it and rinse it with a hose. Most of the time I dont have to scrub it at all. Every once in a while, I'll get a stubborn spot that I'll have to scrub with a push broom. Ive never had any fading with the awning, or problems with the side of the camper, but I try to keep it off the camper.
2007 Dodge Ram 1500
2017 Shamrock 233s
Waterloo, Iowa
Finster is offline   Reply With Quote
Old 06-14-2019, 08:31 AM   #29
Whatever you use, it can't be sticky. You'll either be unable to unroll the awning, or it will pull itself apart at each layer. The best prevention trick is to use a protective cover when stored, and to periodically unroll it and let it dry after driving in the rain. Try never to roll it up wet.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 06-14-2019, 09:30 AM   #30
Wet & Forget! It works with no hassle whatsoever. A gallon is about $30 but cuts 5:1 for six galloons of cleaner. Use a pump sprayer and do the top and underneath. Let it dry and forget about it. When it rains, it will activate the chemicals and will clean the awning. for underneath. spray it with plain water after letting it dry. The chemicals will regenerate every time it rains.
I also use it on my rubber roof. Completely cleaned it. Have not been up there for over a year now.
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 06-17-2019, 08:35 PM   #31
After trying many cleaners, someone on this forum recommended a product called Zep. Worked great. Got 95%+ of the stains off. Left the stains from a dead bug and leaf but no more mildew.
MentallyRetired is offline   Reply With Quote
awning
