07-25-2021, 04:58 PM
power awning travel lock?
I am looking for ideas on how to secure our Dometic 9100 series power awning for travel. I have seen several RV's alongside the road and have been able to stop and help one get their awning back in place after a gust of wind unrolled it. What does everyone use for their power awnings for going down the road?
07-25-2021, 05:33 PM
Part-Time Campground Host
I've towed our TT over 25,000 miles and have never had a problem.
Did the folks you helped give a reason it unrolled other than wind?
I guess if your worried you could strap it with a bundle tie or tie-down strap.
Craig & Cath
Days camped since 2015(retirement): 1687
07-25-2021, 05:42 PM
Well, I am not real worried. The others I have seen were not power awnings. I always used to strap my manual awning, but this power awning does not have a means to lock the arms. I thought there might be something out there that would lock the roller.
07-25-2021, 05:44 PM
I agree... If the roll will not UNROLL the awning cannot pull out... alternatively drill a hole through one or both awning arms and insert a bolt or stiff wire thru all of the holes to bind the arms together...
personally I have not done this with my 9100 series awning
2014 Shamrock 183
07-25-2021, 05:45 PM
Trailer Park Supervisor
The motor locks it.
Yes, I drink the water!
07-25-2021, 05:57 PM
Originally Posted by NJKris
The motor locks it.
Yep. I think your correct, but didn't want to say that as I wasn't sure.
Craig & Cath
07-25-2021, 06:03 PM
Just what I know from my Dometic. Without something to spin the motor, it's going nowhere! I think you have to use a drill and proper bit/socket to run it if motor fails.
07-25-2021, 06:04 PM
Yep and remove the rivet/set screw on the power side.
Craig & Cath
GLCM Warrior
I put one of these on our awning:
https://www.awninglock.com/index.shtml
Oh, and if I remember, I also pull the awning fuse to prevent burning up the motor.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
07-25-2021, 06:51 PM
I understand that the motor is supposed to lock it, however, I read somewhere that the brake in the motor can be overpowered by a strong gust??
Just trying to hedge my bets.
07-25-2021, 06:56 PM
old manual awnings YES . NEW awnings prob. not.
07-25-2021, 06:58 PM
Man, if it's that windy, I'm not towing! Mine is TIGHT when retracted, can't imagine wind unfurling it. If it makes you feel better, get on step ladder and tug at it. Mine does not budge.
07-25-2021, 07:01 PM
Thanks to everyone for the feedback.
07-25-2021, 07:12 PM
Originally Posted by Lefty59
How is the motor going to get burned up unless you are holding the out/in button in after the awning is already retracted all the way in? And even then the fuse should blow before the motor burns up, that is the purpose of having a fuse in the circuit.
And a properly adjust motor that is not slipping should be all that is required to keep the awning in the fully retracted position regardless of wind gusts - except maybe in a hurricane or tornado.
07-25-2021, 08:08 PM
GLCM Warrior
Awnings unrolling while going down the highway has been discussed several times on the forum. Here's one thread:
https://www.forestriverforums.com/fo...tml#post612396
The manual for my awning states that power to the motor circuit should auto disconnect whenever the 7-pin connector is plugged in...but in testing this, I found it to be untrue...so, I pull the fuse.
2014 Wildcat 312QBX
07-25-2021, 08:39 PM
Interesting, I have never heard of a power awning disconnect with the 7-pin connector connected. There would be no need for it. There is no power going to the awning motor unless the switch is held in either the in or out position. But, anyway, to each their own. Some people disagree with me turning off the circuit breaker at the power pedestal before plugging in the shore power cable....
07-25-2021, 08:55 PM
No matter what you do someone is going to disagree with you and have a reason for doing so. So far I’ve never heard a valid reason NOT to flip the breaker prior to connecting/disconnecting the plug.
BIRDS AREN’T REAL
07-25-2021, 08:58 PM
Just like I guess there is no valid reason for not pulling the fuse for the awning when travelling....as long as you are willing to go though the effort of doing it.
07-26-2021, 12:32 PM
The motor locks it.
I'm quite certain that's right. Over 20,000 miles and I have not had an issue. If I was concerned, a piece of insulated 14 or 12 gauge wire could be slid behind near the top of each arm and given a couple twists.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
07-26-2021, 12:54 PM
I've never had an awning unroll while going down the road, manual or electric. But I have seen it happen, I just don't know the specifics of why it happened.
I have a friend who delivers RVs all over the country and he always zip ties the top of the awning arms just for safety as he never knows the condition of units from the factory. Just his habit. He has picked up factory units with loose rims, flat tires, loose hitch bolts, flapping roofing material, a/c that falls off, slide outs that migrate out, windows that fall out on the first bump. The list goes on and on. They give him crap about how long it takes him to get ready to leave, but there is a lot he checks to save himself headaches on the road
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
