Think of the rubber tube as a spacer held in with a screw. Look down inside with a flashlight. When these are installed there is a layer of butyl caulk used. Great stuff. Since you should use care tightening the screws so as not to strip any thing, the caulk tape compresses somewhat over time, snug your screws up, wait a few weeks and repeat the process. That caulk tape will help to adhere( glue) it to the siding. So once all your screws appear to be out, use a putty knife to gently remove the T latch
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
