Old 05-15-2017, 01:34 PM   #1
Replacing pleated blinds
We would like to replace the pleated day/night blinds with faux wood blinds. Do they make special blinds for RVs that have more secure mountings than those used in the home? Can I just mount the generics from the big box stores? They are much less expensive than custom blinds and the fit is not critical since they are mounted outside the frame.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 05-16-2017, 07:20 PM   #2
Woody,I would think that they would fit fine. I agree width would'nt be that critical. I don't like the pleated blinds either. Been thinking along the same lines as you.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 05-16-2017, 07:44 PM   #3
Thanks for the response. I think they will work too. I'm just unsure the mounting brackets will hold up to the movement but I'm sure I can make it work.
Andersen hitch
Old 05-16-2017, 07:48 PM   #4
It will depend on what you have in the way of frame work around the windows. Mine feel pretty solid.
Old 05-19-2017, 01:41 PM   #5
DustyRoads's Avatar
Just be careful what you put behind stove. They should be metal not wood or fabric.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 05-19-2017, 04:29 PM   #6
Thanks. I have metal mini blinds there.
Andersen hitch
Old 08-02-2017, 12:07 PM   #7
Update
**** UPDATE ******
I bought faux wood replacement blinds online from a company called Select Blinds, and I'm very pleased with them. The blinds are surface mount with very secure brackets that have a positive latch. The blinds can be ordered in exact widths AND length. No adjusting length like the blinds available locally. I like that you can specify which side you would like for the draw strings to be located, and you can select either draw cord or twist wand to adjust the angle of the slats.
My original blinds have a fabric valance at the top. The head rail on the new blinds was too thick to fit beneath the hardware and fabric of the valances. I remedied this by making a 3/4 inch spacer from wood and mounting the valance on this. I painted the spacers to match the other trim.
Total cost for 5 blinds, from 20 inch to 72 inch, was just over $200.
Andersen hitch
