Old 04-02-2021, 03:17 PM   #1
Shrinking Window Seals
My 2017 trailer noted below has very common windows which means my problem is likely also very common. Several windows are showing seal separation as seen in the attached images. Ive found a lot of window information in this forum and online but it is difficult to determine my course of action. A few questions that the forum can possibly help with-
Can these seals be repaired without them being removed?
Can the seals be replaced without removing the window?
If I dont act immediately will rain enter the camper?
Any other thoughts about this problem?
I religiously lubricate my rubber slide seals with Thetford Protect All but now I see that I should have been doing my window seals as well. Thanks for your help.
ID:	251038   Click image for larger version
Pete
Coachmen Catalina 2017 293RLDS
2017 F250 XLT Diesel Crew Cab
pete100 is offline   Reply With Quote
Old 04-03-2021, 09:24 AM   #2
SeaDog's Avatar
The shrinking seal happen allot. I think what I would do is purchase a length of seal cut it to fit that space and secure the seam with black RTV. That is the easiest fix I can think of and yes leaving it open would allow water and bugs to get in there.
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-04-2021, 07:05 PM   #3
Tiguan Tow r's Avatar
You can remove/replace the vertical seals easily. This video shows how.
https://youtu.be/tzLo3EZb3fQ
We bought window seal for a previous Jayco through the Jayco dealer.
Tiguan Tow r is offline   Reply With Quote
window, seal
