Old 09-23-2007, 10:05 PM   #1
Young Travelers's Avatar
Solution to window sweating?
its starting to get cold at night, (freeze warning tonite, had snow on thursday of last week)
anyways, what's a good solution to cleaning up the water from window sweat? and any reccomendations to keep it from puddling up in the window frames?
also with the AC unit off, does air still flow thru it? (Heat loss)
should i wrap it up and cover the vent inside the TT? THANKS
YT
2007 Dodge 2500 QC 4x4 LB CTD
2004 Forest River Salem 39FBRB
2005 Kawasaki 700 4x4 ATV
2002 Kawasaki 300 4x4 ATV
2008 Chinese 110CC kids atv
4 Great Kids......
and a wonderful wife of 12 yrs now.....
Could not ask for more
Young Travelers is offline   Reply With Quote
Old 09-24-2007, 07:17 AM   #2
RAC
A dehumidifier will remove the moisture that causes the condensation
RAC is offline   Reply With Quote
Old 09-24-2007, 07:43 AM   #3
We just place towels on the sills to soak up the water. Too cheap for a dehumidifier.
And yes you will loose heat through your AC unit. Not a lot but there is some loss. A solution I saw once was a custom made cover that used velcro to cover it up.
greg
aintgotnun is offline   Reply With Quote
Old 09-24-2007, 12:43 PM   #4
powerboatr's Avatar
when it starts to get cold here, we bring in the dehumidifier and let it run on high
right in the middle of the main room
we have the double pane windows but they all still sweat, its the cold to warm alum syndrome
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 09-24-2007, 06:56 PM   #5
Quit breathing so heavy.
+1 on the dehumidifier. Never thought about making a cover to velcro on the A/C unit. I'm assuming that could be done inside. Great idea!
kilowattkid
2003 F-250 5.4 manual gearbox w/ 4.10's
2007 Puma 29RKSS
kilowattkid is offline   Reply With Quote
Old 09-24-2007, 09:02 PM   #6
I ain't sayin nuthin!!!
Old 09-24-2007, 10:07 PM   #7
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Most times...I use the towel as well. By the time it gets that cold out...the season is over for us. No need to dehumidify.
Some folks use the crystals that absorb moisture with some success. (Damp Rid)
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 09-25-2007, 12:17 AM   #8
Thanks for the Tips, and I will cover the AC vent on the inside....
YT
4 Great Kids......
Old 11-08-2007, 09:18 PM   #9
JJ
I bought 3 different eva-dry for less than 880 bucks works great. Evadry 1100, 300 and 500
jj051797 is offline   Reply With Quote
Old 11-09-2007, 11:57 PM   #10
welshman599's Avatar
Send a message via MSN to welshman599
Often, just adding a little airflow over the glass is enough to eliminate condensation, we keep a couple of little battery operated fans on hand and click them on low at night aimed at an angle to the window, works pretty well. Something like one of these. http://www.personalfans.com/Merchant...egory_Code=CLF
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 11-10-2007, 08:17 AM   #11
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
There are only two choices that I know of to reduce sweating - 1) Mechanical removal of moisture in the air and, 2) Ventilation. This last may be counterintuitive, considering that you are trying to stay warm. But you might be surprised at what slightly cracking a window and a vent can do for you.
dimurrrw is offline   Reply With Quote
Old 11-13-2007, 04:40 AM   #12
we leave the ceiling fan on most the time, which helps, and I used one of the old towels the wife said i could have.... and cut it into 3" strips, as long as the base of the windows. folded the strip 3 times and placed it in the "track" in the bottom of the window and the Front Sliding door. we keep and eye on them and when wet we wash and DRY, and replace them every 4-5 days... wokrs quite well,
Cost....$0.
YT
4 Great Kids......
Old 07-15-2008, 09:57 AM   #13
It is a good practice to run a dehumidifier in your RV every spring for a week or so. This will elimminate that dank stale smell you have when you first oper it up. I leave mine running for two weeks and it makes an amazing difference.
Jim
Mork is offline   Reply With Quote
