Old 05-14-2020, 07:35 PM   #1
Storage Bay Door Problem
Hello,
Today I took my 2004 Georgetown out of the garage where I had all four spings replaced -- and it does ride better now -- only to find out that at leat two the driver side storage bay doors didn't operate properly.
Upon closer inspection I found out that all the door hinges are attached to the same part -- some sort of a railing probably -- and that the railing has become lose, no longer solidly attached to the main frame.
I guess it's not a big deal to either replace or repair that railing, but the screws holding it in place are covered by some kind of molding (plastic?), and I can't see how this molding is removed (sliding it out or popping it out).
I include 3 pictures to try and clarify what I mean. The first pic shows a general view of the location, The second shows a closer look at the "molding" itself, and the third shows a close-up of the "railing" hidden by the molding. As you can see, a gap has developped.
Any suggestion is welcome.
Maurice
ID:	229087   Click image for larger version
ID:	229088   Click image for larger version
2004 Georgetown XL 308DL
mlafleur is offline   Reply With Quote
door, storage
