Old 08-14-2019, 06:59 PM   #1
Tilting Awning
We are fairly new to trailer camping and of course learning more each day.
We have 2015 FR Air 215. Ive been researching tilting awning for rain run off.we have pulled down on awning arm and tried tightening wheel. Even though wheel is tigh awning still goes back up. The awning is a dometic.
VirginiaQ is offline   Reply With Quote
Old 08-14-2019, 09:07 PM   #2
turn it real tight, it will hold
jeyes1957 is offline   Reply With Quote
Old 08-15-2019, 05:27 AM   #3
My dealer mechanic, during the PDI, told me that I can pull down and crank the hand screws tight to lock an angle on one side or I can leave them loose and that the Dometic awning is designed to collapse one of the leg springs at around 8 LBS of water and self-dump the weight. I have not been out in rain as of yet to test his theory, but I was wondering if anyone else has heard or this self dumping? I grew up with a park model camper that had fixed arms that clicked into various positions of angle or tilt. My father would always keep one outer corner dipped lower than the other for rain shedding. Based on my growing up in the 70's and seeing that, I am reluctant to trust this spring loaded auto-dump.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 08-15-2019, 05:38 AM   #4
They do self-dump however the concern is wind. If I don't clamp down and strap down, the wind will blow it over. I still tilt one end, clamp the screws down and then tie it down. Trust me, after losing one awning and scratching my full paint unit, I won't make that mistake again.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 08-15-2019, 06:27 AM   #5
GalsofEscape's Avatar
They do auto dump, but I usually set a tilt so the rain sheds in the direction I want. But I just endured a gully washer and the tilt had not stayed set for some reason and I had not noticed. The auto dump feature worked, the one side dropped, shed the water and popped back up, then the other other side dropped but it was raining so hard, it stayed down and the constant waterfall was spectacular. It only lasted a few minutes, so when the rain finally let up, the awning popped back up. Got a nice car wash out of that storm.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
Old 08-15-2019, 09:49 AM   #6
I've never seen the auto dump work on ours. I'm afraid to let it get too heavy.
What year and type of trailer do you have?
Old 08-15-2019, 01:06 PM   #7
bikendan's Avatar
Not all awnings have a auto-dump feature. I have the same brand of RV that the OP has and it does not have an awning with auto-dump.
Old 08-15-2019, 01:57 PM   #8
Retired Panpsychist
Theo's Avatar
The "wheel" is actually a bolt with a plastic star-shaped knob on the end. When you tighten it (righty tighty), it clamps down the assembly by drawing a small metal plate against the awning strut and the slide piece attached to your RV sidewall. So...there doesn't seem to be any clamping going on!
Try getting on a step ladder to closely examine the effect of tightening the knob. Can you see the bolt going through the metal plate? Are the threads intact? Is there a metal plate? What happens if you loosen the knob?
Photo might help, too.
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
awning
