Old 04-15-2024, 02:09 PM   #1
Wildwood x-lite passthrough door replacement
Hi everyone, I messed up my passthrough door trying to back my trailer into my driveway, luckily only the door received damage. Is there a place I can buy a new door? I attached a picture of the sticker on the inside of the door.
worldcup84 is offline   Reply With Quote
Old 04-15-2024, 02:20 PM   #2
Forest River Dealer
At any Forest River dealer?
Or take careful measurements and put this
rv baggage door
into Google. Looks like these sellers make you buy the frame, too.
Larry
Larry-NC is offline   Reply With Quote
Old 04-15-2024, 03:43 PM   #3
yeah I think it's all one part.
Old 04-15-2024, 04:31 PM   #4
Then don't forget...
Then don't forget to order a roll of butyl tape when you order the new door/frame.
If the old frame doesn't want to come off, use your heat gun to heat it a little to soften the old tape.
Larry
Old 04-15-2024, 09:14 PM   #5
Nice, thank you I literally did not know about that at all, never even heard of that kind of tape before I will look into that.
Old 04-16-2024, 08:39 AM   #6
Butyl tape
Don't be fooled by the name. It's not especially adhesive (sticky). It's actually a soft caulk, called tape because it's about 1" wide, 1/8" thick, malleable (like modelling clay), comes on a roll with a paper separator, and is tacky to the touch. You can put it between two surfaces and when you tighten them together, the excess oozes out and can be cleaned off.
Larry
door, lite, replacement, wildwood
