Originally Posted by dotsonjc
My in-laws had a pesky window leak, which they took to the dealer several times under warranty to have worked. The window had been recaulked both time; however, still leaked. I took a look at the window, and noticed the plugs for the weep holes had never been removed (window had weep holes top & bottom, I guess so it could be mounted either way). Removed the bottom weep plugs and never had another leak.
Check your weep holes.
I have had a similar issue with weep holes. During heavy rain, especially wind driven , rain comes down the window and backs up in the channels eventually spilling over the channels, down the walls, and even into electric outlets causing ground fault.
Depending on rain intensity and wind direction this has happened on all 11 windows on my destination trailer.
I reported the issue to the dealer less than a month after delivery. The factory sent the dealer service to fix by drilling new weep holes. It looks like they only drilled on hole in each window. We still have the problem and now the window company says it’s debris blocking the weep holes and refusing to do anything. The unit has a full cover on it most of the year and we have had to vacuum the water out of the channels every rainfall. Help?
