Old 05-17-2020, 01:04 PM   #1
Betz's Avatar
Window shade anchors
Trying to figure out how to release the window shade cords to lower them. Accordion type shade with vertical cords leading to button anchors below the windows. Thanks for any guidance and insight.
Betz is offline   Reply With Quote
Old 05-17-2020, 01:22 PM   #2
A picture would help. Many RV shades are help in place by the tension of the string. If you have shades like that, you just pull the shades down by hand. I just pull it away from the window ever so slightly to avoid dragging it across the window frame.
Hope that helps.
Skip12 is offline   Reply With Quote
Old 05-17-2020, 01:25 PM   #3
paverdave's Avatar
Try grabbing them a the bottom and pull up or down....be careful and use both hands....
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD SLT short bed w/gravity flow75 gallon Fuel Tank
Firestone Airbag Ride Rite system
paverdave is offline   Reply With Quote
Old 05-17-2020, 01:32 PM   #4
X2^^
What do you mean release so you can lower them? You lower the accordion shades by grabbing the bottom of the shade and pull down. They just slip along the cord. To raise, you lift upward from the bottom. If the cord is too loose they won’t stay up.
To loosen/tighten the cord you loosen the button with a screwdriver and pull on the cord until tight as you want.
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 05-17-2020, 01:59 PM   #5
Betz's Avatar
Hope that helps.
Duhhhhh ! I feel so stupid! I was way over thinking this! Thanks for reducing my Prozac load for the day
Old 05-17-2020, 02:06 PM   #6
Welcome to the forum from the Space Coast...
window
