Old 06-18-2020, 06:56 PM   #1
mikkeeh's Avatar
Window weatherstripping
So, my 2018 Coachmen Chaparrel 360FL has this issue. The rubber around the windows appears to be shrinking and pulling away. Currently in about 6 different places. If you really work at it, you can get it close to going back into place, but it wonít stay. Whatís the fix?Click image for larger version
mikkeeh is offline   Reply With Quote
Old 06-18-2020, 08:44 PM   #2
I don't have a good answer but am wondering if the rubber is a single piece. I'd consider pulling it out at the bottom and gluing in a short section of additional rubber. Even if the added piece didn't exactly match, if you centered it at the bottom (or top) it probably wouldn't be very noticeable. You could alternatively replace the entire gasket. The big box stores have a lot of choices of gasket materials https://www.amazon.com/s?k=rubber+wi...f=nb_sb_noss_2
2205S Rockwood
F 150 Lariat 3.5 Ecoboost Fx4 Max Tow
Equalizer WDH
flyflotrtim is online now   Reply With Quote
Old 06-19-2020, 03:20 PM   #3
I have the same issue on my 2018 chaparral. I have pulled it out and tried to fit it into the corner and it seems like it does not want to ďsnapĒ into place like it does on the long straight runs
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-19-2020, 03:21 PM   #4
Have you asked Christi at coachmen? She may be able to recommend a replacement part.
Old 06-20-2020, 05:14 PM   #5
My dealer showed me how to pull a section and then pull/stretch the part that is out. You can get it back together tight at the seams but it takes some work. The corners are very hard. If they donít go back in at the same place the memory in the weatherstripping makes it difficult to get back in. Try not to pull the corners loose. I feel like overtime it would be best to replace them. Trying to see how mine hold up after doing this. Been a month or so and still looking good now.
The Racer is offline   Reply With Quote
Old 06-20-2020, 08:29 PM   #6
Makes sense. I will give it a try. Thanks for the tip.
Old 06-20-2020, 08:40 PM   #7
Your very welcome. Good luck with it.
window
