frayed or damaged wire to slide
I had the same problem. Only the light fixtures in the slide were affected. I got underneath the trailer and opened part of the protective undercover and found a 3 wire (+,- and ground) that had been pinched by the slide movement somewhere and was almost totally severed. The wire was designed to move with the slide, but somehow it got caught and was damaged. Repaired the wire and secured it a bit better so pinching was less likely.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
