01-16-2022, 11:43 PM
Adjusting for one upper corner of slide out
So, I've been a certified auto tech for over 30 years, yet this one stumps me. Frustrating. My brand new Salem Hemisphere's passenger side slide out, will not seal on the upper right hand corner when retracted. All other 3 corners are tight. The slide tips in during retracting, however right before the corner touches, it stops and backs out 1/4" from the seal. Everything is tight, centered and level. I've checked the floor height on each side and it's within Lippert's through frame electric specs. Since I live in Seattle, and bought it out of state, no dealer will touch it. Nice support system Forest River, thanks. I've made several adjustments in/out, up/down and nothing makes a difference. Any help would be much appreciated. I can't be the only goon that has seen this.
01-17-2022, 12:56 AM
What brand of slide system do you have?
2015 335DS
01-17-2022, 01:15 AM
Lippert through frame electric
01-17-2022, 02:50 AM
You do know that you can use an independent RV shop or mobile RV technician, right?
You just need to get pre-approval from FR and be willing to be reimbursed.
01-17-2022, 02:58 AM
FR considers slide adjustments to be maintenance, so they wouldn't help out. Worse case i use a slide lock to pull it in the rest of the way until I figure out the fix.
01-17-2022, 07:43 PM
Certified tech
A certified tech would be delighted to have the service manual. Here it is.
Larry
01-17-2022, 08:52 PM
Larry, thank you however i didn't see an attachment
I got it..slight color difference in the text
01-17-2022, 08:54 PM
I already have that one, however it doesn't address the adjustment, if any, for just one top corner not seating.
01-17-2022, 10:04 PM
My curb side slide seals on all but left upper corner seal has les than 1/8" of gap.The vertical board on my is slightly bowed twisted and i think that why mine doesn't seal.it doesn't leak or do i get any wind noise or notice draft from that corner.i did adjust the outward stop position i shorten mine up .25" that help some as to me wss trying to push the bottom of slide out witch cause top to fall inward.i think slide is trying to over exstend.
01-18-2022, 11:11 AM
Originally Posted by wmtire
To my recollection, yours is the only post I have ever seen about it so am not sure just how many "All" encompasses. Try the extensions and see if that solves it for you.
Sent from my LM-X320 using Forest River Forums mobile app
Will the extension fix my slide issue?
01-18-2022, 11:20 AM
Lol, it will not. I moved all these off topic posts to their own thread.
 2011 Flagstaff 831 RLBSS
Most people write congrats because they don't know the spelling of congrajulashions
01-18-2022, 11:35 AM
You can't just adjust one corner by itself. You have to do a complete mechanical room adjustment (vertical & horizontal), which starts on page 13 of the manual.
2016 Salem 27RKSS
01-28-2022, 11:30 AM
So how did make out?
01-29-2022, 01:31 AM
Did the repairs myself as I dont trust any goon to work on my RV. The upper horizontal flange is convexed in the middle which is the cause of my issue. Able to get it close enough to make contact, built a factory appearance perimeter flashing to redirect water from the top and front, and will use an expandable slide lock while towing. All good now.
01-29-2022, 11:21 AM
Good recovery
A man after my own heart!
Couldn't get the bow out?
Larry
01-29-2022, 11:24 AM
Myself being a contractor for the past 39 years, made me wonder why there is no "flashing" that would direct water out and over the top of the slide outs.
There are aluminum extrusions that could be installed on the wall so rain then goes over the slideout seal instead of just running down behind it.
A slideout topper would accomplish this too, but is way too much. I find when my slides are out I have better leak protection than with them in.
01-29-2022, 12:05 PM
I didn't want to chance "massaging" the heavy metal frame back into a perfect plane. The hardware used by the factory is marginal at best and if anything gets loose, it's too hard to repair.
