Old 07-08-2020, 09:24 PM   #1
Apex 245 bhs 2020 slide leak
My apex 245 bus 2020 slide has started leaking above the bench on edge of slide. It is not on the inside part next to seals. Water drains off the back of the slide and not run toward the camper. However, I checked the slide during the last rain and water seems to form a small puddle in the middle of the slide. The carpet under the forward bench is getting damp after leak. Any thoughts?
William2020 is offline   Reply With Quote
Old 07-13-2020, 07:31 PM   #2
It's it happening when parked or after driving in the rain? My inlaws had an apex and it leaked under the slide while driving. There was a screw sticking out that cut the bottom seal. Something with the swing arm that had the power on it.
Ole_blue is offline   Reply With Quote
Old 07-13-2020, 07:41 PM   #3
Parked. With slide out
leak, slide
