Old 04-22-2021, 03:32 AM   #1
Bottom corners ripping off
This is a 2018 Flagstaff Windjammer 30WFKSV. I have 2 slides. All 4 lower outside corners are ripping off and out of the installed position. Is this a poor design and a Forest River warranty fix? Seems to me it should be.
ID:	252616   Click image for larger version
dannybye is offline   Reply With Quote
Old 05-06-2021, 09:29 PM   #2
Slide floor
I would have that looked at by an RV shop or even mobile repair person. Mine don't look that way at all and I'd be afraid the floor has separated from the wall for whatever reason.
While in Houston for an extended stay, I observed several mobile techs. replacing a floor on a slide out in an adjacent spot. It took several days and they constructed a make shift tent over the job as it rained several times.
Charles Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2017 Rockwood Windjammer 3029
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 05-06-2021, 10:18 PM   #3
The plastic skies are to help shed water from going under slide floor and causing rot.On my two slide they were like yours so i got some screws and fastened plastic to bottom of slide floor i put screws about every two inches i will go back in couple weeks and seal them with lexel sealer.on my bedroom slide they stapled them to bottom.
I have 5th wheel.
If your is under warranty have dealer fix it.
After looking a t pictures i would replace yours the are pretty deformed.
Gmoney67 is offline   Reply With Quote
