Discovered that one of my rollers on the bottom part of my rear slide has stripped out of the screw and is now bent outwards. Due to the angle, it's digging into the metal. After looking at the forums and youtube, it seems like the first step is definitely to remove the slide roller so it stops digging into the bottom of the slide.
1 - What are the risks of removing this if I cannot replace it right away?
2a - Seems like once I remove it, I should jack up the slide a little bit to create a gap?
2b - Seems like putting 2x4s under each end of the slide then jacking up a little is the best way to achieve this? What could I break here?
3 - Once jacked, install the new slide roll
4 - Lower jacks
Is this accurate? Any experience here?
https://photos.app.goo.gl/WSBjjhTEJtpzhqNF9
