Old 06-23-2019, 01:15 PM   #21
Originally Posted by Chuckinca View Post
Is the "equalizer" part of the Lippert slide?
Yes. If you look underneath you'll see two "racks" which are the support tubes with gear teeth on the bottom and next to the frame there is a shaft with two pinion gears on it, one engaged in each "rack".
When the single motor (linear actuator) pushes out or pulls in the slide, this equalizer mechanism makes sure the front and rear move the same distance.
Side note, these support tubes need to be kept clean and some good dry lube spray applied as routine maintenance. Ignoring this maintenance will lead to slow slide out movement and eventually sticking that will just yield a ratcheting sound when your slide sticks during extend or retract.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-28-2019, 08:36 AM   #22
Yes, but...
Originally Posted by Bryan294bh View Post
Can the slides go out while hooked up to the tow vehicle granted its level... We are going to have to overnight on our way to our destination..
The slide shouldn't be a problem but I'd recommend that you unplug the trailer from the tow vehicle. If you leave it plugged in you can discharge the tow vehicle battery when using 12v items in the trailer. You don't want to have a no start in the morning.
2018 Shadow Cruiser 265RLS
2018 Chevy Silverado 1500 with 5.3 max tow package
Shiawassee County, Michigan
Tacky is offline   Reply With Quote
Old 06-28-2019, 08:52 AM   #23
david_reaves's Avatar
I agree with the commenters that say to put the hitch load on the jack, and not the tow vehicle. I also agree that unplugging the trailer from truck is a great idea. We normally run the stabilizers down when putting the slides out, too. As long as the truck is hitched, no one will likely think you are homesteading.
david_reaves is offline   Reply With Quote
slide, tow vehicle
