Old 05-21-2020, 08:11 AM   #1
Favfour's Avatar
Do levelers have to be down for slide operation?
I know the basic rule that levelers should to be down prior to slide operations. I keep my RV in a pole barn a few hundred feet from the house. I pull it over to the house before and after a trip to ease in loading and unloading. I like having the slides open to load or clean up after a trip. Seems excessive to let suspension out (diesel pusher) and put levelers down just for a day or two sitting in the level driveway. Thoughts?
Favfour is offline   Reply With Quote
Old 05-21-2020, 08:17 AM   #2
bubbles's Avatar
Unless a diesel pusher has some sort of interlock the answer is no.
Old 05-21-2020, 08:25 AM   #3
Many RVs come with slide outs, but not all even have levelers.
If your RV has known problems due to frame twisting on uneven ground, and if your barn floor is very uneven, then maybe in your particular case you need the levelers down. But, as a general rule, the answer is no.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 05-21-2020, 08:41 AM   #4
While I try to get as level as possible and not be in any kind of twist when parking somewhere that I'm going to extend the slides, I don't 'level' the unit before deploying the slides unless I'm staying.
My unit sits under an overhang of a pole building garage. I seldom have the stabs down parked there (unless we have guests staying in it) and we run the slides in and out all the time.
I've only ever seen manufacturer's voice concern over severely out of level units or those on a twist of some sort when it comes to using the slide(s).
Days Camped: '18=51 '19=58 '20=110 '21=47
Old 05-21-2020, 10:12 AM   #5
Isn't that tow vehicle a little small for that size trailer?
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-21-2020, 10:17 AM   #6
Nah... salesman told me it was golf cart towable!
Old 05-21-2020, 01:38 PM   #7
jeff64's Avatar
How many times have you been to an rv show or dealer lot, walked through a rv and the stabilizers weren't down . Look next time, there's your answer
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 05-21-2020, 02:09 PM   #8
Favfour's Avatar
Very good point!
Old 05-21-2020, 02:35 PM   #9
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
Hes got 2 of them, must be a dually !!!
Cover Dog is offline   Reply With Quote
Old 05-21-2020, 04:18 PM   #10
Just as confused as you
Scrapper's Avatar
Originally Posted by Cover Dog View Post
He’s got 2 of them, must be a dually !!!
Actually, 5picker has 3 golf carts, one for pulling, one for pushing, the last for turning, but he can only make right turns.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 05-21-2020, 04:55 PM   #11
Nah, he put air bags on the cart.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 05-22-2020, 09:25 AM   #12
LOL!...
I actually have six!
The three you see... the left turn cart, the reverse cart and the toad are in the shed behind.
Old 05-29-2020, 12:00 PM   #13
Level For Slides
I don't think it matters if the levelers are down when you extend or retract the slides. But, from my experience, it does matter if your rig is not level.
Slide actuation systems don't have a lot of excess pulling/pushing capacity so if your rig is not fairly level it can cause the slides to get off center and bind. That can strip gears. Also you may end up pulling a slide, which is very heavy, up hill. That adds some of the slide's weight to the already large frictional drag of just moving the slide across its rollers.
There are times when I am just staying over night and my rig is level that I put out the slides without the jacks being down. But, if my rig is not level, I always level if first before actuating the slides. And, sometimes, my bigger slide actually tilts my rig even with the levelers are down. When that happens, I manually tweak the levelers to bring it back to level.
hikerjohn7 is offline   Reply With Quote
slide
