Dreaded "Slide won't Open" without manual help
I have a 2022 Rockwood mini-lite 2511s
I made a mistake, and opened the large slide out just a bit then closed it. Next time I tried to open it, it clicked but would not open. I use the manual screw, turning it barely an inch counterclockwise, and it worked find.
The a week or two later, it would not open again unless I turned the manual screw just about an inch or so. I can hear a clunk as it disengages or something like that. It worked.
I went under and lubricated everything I could see or get to. It worked fine, I opended and closed it twice.
Thoughts? I've heard that this can be a recurring problem now. It's an easy fix to get it working ... but could it get worse?
If so, how is something like this fixed? A realignment of sorts at the dealer's garage?
Thanks in advance
_______________________
2022 Rockwood Mini Lite 2511s
2020 Ford Expedition XLT - Max Towing
