Did you repair the 'soft spot'?
Dallasrules,
Did you ever fix the "soft spots" the roller goes over? Sounds like you had basically the right idea of how to fix the problem.
I would suggest repairing the soft spot by removing the soft, splintered out material then building the depression up with epoxy flush with the existing wood surface around it. Epoxy you might look into is what is called thixotropic epoxy, which is sort of a gel like epoxy compound that has a heavy body and will 'hang' on vertical surfaces, as well as overhead surfaces to a certain degree, unlike the typical. quite liquid, higher viscosity epoxies.
You might even be able to use something like Bondo for filler. The epoxy however, could be absorbed into the adjacent loose wood fibers in the area and kind of resurrect the wood structurally.
Then your idea of a thin metal plate over the area I believe has merit. However, I would use something thinner, not aluminum though unless something like a T-6 structural alloy, not mill aluminum, but possibly stainless steel of 1/16" to 3/32". Using a thinner material shouldn't pose any challenges for the roller to pass under it, and it should only need to kind of provide a 'smoother' track for the roller with the epoxy providing the necessary strength back to the wood. You might even grind down the front and back edges of the metal plate to a taper to give the roller a 'gradual' transition. Good success with your project.
