Old 04-25-2020, 07:49 AM   #1
How do I open slide out manually
I have a 2005 forest river travel trailer. The hydraulic fluid leaks as you can see in the photos. This trailer is permanently parked on our private lake lot. I have removed the tank to see the o-ring. How can I manually open the slide outs so that we can use the trailer until I fix the hydraulic system?
ID:	227614   Click image for larger version
denboot is offline   Reply With Quote
Old 04-25-2020, 08:17 AM   #2
Mr. Dan's Avatar
Which division of FR made your trailer? Shasta, Wildwood, Cardinal, Sierra, etc.?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 04-25-2020, 08:20 AM   #3
missing photos
I have edited my post to include the photos.
I purchased the trailer used so I do not know which division.
Old 04-25-2020, 08:59 AM   #4
Mr. Dan's Avatar
You should be able to look on the side/front/back and see something like “Wildcat by Forest River”, etc. it’s also on my title and insurance papers.
Old 04-25-2020, 09:27 AM   #5
forest river division
It is a Forest River Salem.
I thought that is just the model name for this trailer
Old 04-25-2020, 09:36 AM   #6
Mr. Dan's Avatar
Forest River is the corporate name like General Motors.
Salem is the division name like GMC and Chevrolet.
You have a particular model designation - maybe on a decal by the door. May have numbers in it like my Wildcat 295RSX.
Truth is -- I can't help you but I know from experience SOMEONE here knows something about a Salem's slide-out mechanics.
Old 04-25-2020, 12:28 PM   #7
Retired JSO's Avatar
Having hydraulic slides with a lippert pump, the manual way to move the slides require you to insert a square drive bit into the end of the electric pump motor using a portable drill.
Retired JSO is offline   Reply With Quote
Old 04-25-2020, 01:25 PM   #8
OldJarHead's Avatar
Look for an access hole on the side of the coach opposite from the slide you want to manually crank out. Insert the tool and crank your life away ��
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
OldJarHead is offline   Reply With Quote
Old 04-25-2020, 02:44 PM   #9
We are talking about two different systems here. The OP has an hydraulic system. Let's not confuse his issue with another.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 04-25-2020, 09:00 PM   #10
You are correct. They are each talking about a different system. I answered the one with the crank out pictures first and then the OP question. Just don't want to confuse you as well.
ProfChuck is offline   Reply With Quote
Old 04-25-2020, 09:53 PM   #11
Just as confused as you
Scrapper's Avatar
When someone (Lakeman) hijacks another persons (denboot) thread it does nothing but cause confusion unless you click the quote button on the post your responding to. You can use the multi-quote button when you are responding to different posts made in the same thread. You can then basically separate the posts and respond to each in turn.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 04-26-2020, 05:10 PM   #12
For the OP and others. The picture showing the gear and cog . That is on several different manufacturers slides all it does is keep the slide square. I doesn’t matter if electric or hydraulic. It has shear pins holding the gear to the shaft which can shear. I know because I had to replace both with grade 8 1/4-20 bolts.
Old 04-30-2020, 07:34 PM   #13
How do I over ride the system? I don't see anything in the owner's manual.
Old 04-30-2020, 10:03 PM   #14
Scrapper's Avatar
Attachment 228007
The generic manual for your rv will not cover maintenance, operation, or service of your accessories / appliances.
Here is the service manual and other important documents for the Lippert Hydro-Sync Slide-Out.
File Type: pdf Hydro-Sync Slide-Out Service Manual.pdf (2.16 MB, 104 views)
File Type: pdf Hydraulic Operation Fluid Recommendation.pdf (61.9 KB, 42 views)
Richard & Jill
Camping since 1989
Old 05-01-2020, 06:14 AM   #15
how do I over ride the hydraulic system
Thank you for responding to my post.My trailer has the older model hydraulic system. It does not match the pictures in the manual that you posted. I will have to take a closer look at mine to see if the manual procedure is the same.
Old 05-01-2020, 10:26 AM   #16
Scrapper's Avatar
Is there a tag anywhere that has the model number? You may need a mirror to find it as it may be hidden out of direct sight. Remember, the model number may not be listed as such. It might be a model name and a part or serial number.
Richard & Jill
Camping since 1989
Old 05-01-2020, 10:29 AM   #17
Scrapper's Avatar
Can you get any numbers off the tags? I can see 2 partial tags in your picture. One on the tank, the other on the valve body below the red wire. Look on the end of the pump opposite the tank. Is there a plastic or rubber plug which can be removed?
Richard & Jill
Camping since 1989
Old 05-01-2020, 10:39 AM   #18
Site team note:
Split out comments from separate poster to another thread.
Iwritecode is offline   Reply With Quote
Old 05-01-2020, 12:11 PM   #19
manually operating slide ous
I am charging a battery right now. I will be going out to the lake lot later today. I will take a look at the tags, etc.
Thank you
Old 05-01-2020, 12:37 PM   #20
NMWildcat's Avatar
I have never seen a hydraulic slide system with a completely manual override system. The only options I know of are 1) to use the drill method in the pump, but that still requires a working pump and hydraulic fluid. So that doesn't gain you much. 2) disconnect hydraulic line to the slides and move them in and out by hand. But that has drawbacks as they may be heavy and will definitely be messy. Since your RV doesn't travel, you don't have to worry about keeping the slides in place while traveling (which the hydraulic system usually does).
Is it just leaking at the reservoir o-ring? That should be fairly simple to replace. Just take the old one in and get several that look similar.
If it is leaking elsewhere, I would probably take the whole pump out and take it to a hydraulics shop. If hose fittings are leaking, you can have new hoses made up easily. Looks like one of the hoses has some type of tape around the fitting, so that is suspect.
These systems are self bleeding, so you don't have that to worry about.
Keep us in the loop as you solve this.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
manual, slide, slide out
