Old 11-09-2019, 12:38 AM   #1
How to adjust slide
OK, I searched through previous posts to see if I could find a definite answer with no luck. The bottom corner on the front, or left side facing the slide out, has a gap when fully retracted and allows water to enter when traveling in the rain. It's a Lippert "through frame" electric rack type. From what I gather you have to adjust the stop can towards the frame to increase the seal when retracted. The rear corner bottom seal retracted is fine, it's the front bottom corner that I need to draw in about an inch. Anybody know the proper way to do this?
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline   Reply With Quote
Old 11-09-2019, 08:44 AM   #2
SeaDog's Avatar
slides do not need to sit tight against the rig they should have at least 50% compression of the gasket. If I remember right I think there is a video at FR on adjusting the slide I will look in my files and see what i have.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-10-2019, 08:55 PM   #3
Roaminaround's Avatar
Links to adjustments of Lippert slides:
https://lci-support-doc.s3.amazonaws...cd_0001941.pdf
https://dealers.forestriverinc.com/D...ide_Adjust.pdf
https://www.forestriverinc.com/broch...tricManual.pdf
Everything you need to know is there.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
slide
