Old 11-23-2019, 06:24 PM   #1
Fireman
Send a message via AIM to dutch
Hydraulic
Have a2013 Georgetown my hydraulic reservoir is low and the motor is making a bad sounds when I open slides and level, problem is it takes Dexron 111 ATF to fill and they donít make that anymore new one is Dexron 6 which is synthetic can I still use that with what is in there? Help Iím broke down in Fort Chiswell Virginia RV on the way south
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 11-23-2019, 07:02 PM   #2
D W
D W's Avatar
Dexron VI is backwards compatible with Dexron III, but Dexron III or brand equivilant should not be used in an application that requires Dexron VI.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-23-2019, 07:21 PM   #3
mbtelguy's Avatar
The following HYDRAULIC OPERATION FLUID RECOMMENDATION from LCI may help
mbtelguy is offline   Reply With Quote
Old 11-23-2019, 07:48 PM   #4
Fireman
So what your saying is that I have Dexron 111 in my system now and you can mix that with Dexron V1? I thought that you canít mix synthetic with something else because that is what Dexron V1 is.
Old 11-23-2019, 08:04 PM   #5
D W
D W's Avatar
Dexron VI can be added in any proportion to Dexron III
2016 Salem 27RKSS
Old 11-23-2019, 09:08 PM   #6
Fireman
Thanks D W, there is a Auto zone about 14 out Iíll stop and get some, hope that will stop the noise on the hydraulic motor when I run the slides and the levelers
Old 11-24-2019, 11:04 AM   #7
D W
D W's Avatar
Glad to help you out. I went through the same quandary when I reprogrammed my 4L80E transmission.
Happy Travels!
2016 Salem 27RKSS
Old 11-24-2019, 11:53 AM   #8
bubbles's Avatar
I use Mercon 5 for my GT378 system.
Old 11-24-2019, 12:41 PM   #9
NMWildcat's Avatar
Yep, just use the cheapest dex vi or equivalent you can find. The hydraulic systems in RVs have very little demand on them, so no use wasting $$$ on expensive ATF fluids.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
hydraulic
