The hydraulic tank is usually in one of the outside access storage areas. It will be a translucent white with a reddish fluid in it. It should have a mark for full when the slides are closed, as this would be maximum fluid in the tank. Do not overfill, or you will make a mess at some point. This tank would probably not be inside, since the tank has a vented cap and this might let fluid contaminate food. Happy hunting.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
