Old 09-17-2017, 02:40 PM   #1
Novice Travel Trailer Guy
benchmarks's Avatar
Hydrolic Cylinder Ram or Plastic Slide Bearings
Hi,
2017 Micro Lite 25BRDS. How do I know if my slide out operates using hydrolic cylinder rams or plastic slide bearings? I ask because I want to spray on dry lube protectant made by ProtectAll and it states to not use if it has.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 09-17-2017, 07:51 PM   #2
benchmarks's Avatar
Now now don't tell me I have stumped the senior members with this one??
Old 09-22-2017, 09:10 AM   #3
benchmarks's Avatar
Just following up to see if anyone knows. Thanks.
Old 09-22-2017, 09:27 AM   #4
Your "Micro Lite" slides are "NOT Hydrolic!"! Youroo!!
Old 09-22-2017, 11:10 AM   #5
benchmarks's Avatar
Thanks!
Old 09-22-2017, 11:12 AM   #6
Witch Doctor's Avatar
Originally Posted by benchmarks View Post
Hi,
They are not either of the above...
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-22-2017, 11:18 AM   #7
benchmarks's Avatar
Is that good or bad. Your emo thru me off
Old 09-22-2017, 11:53 AM   #8
You have neither of these so the lube is ok. Clean and lube the electric ram/piston as well as the metal tracks and gears on the bottom. I had the EVO and this is what I did with dry lube once to twice a year
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 09-22-2017, 12:06 PM   #9
benchmarks's Avatar
Okay. But I have to ask because I have heard. Do any of these slide outs never need to be lubricated? Are any self lubricated? No maintenance type? Thanks.
Old 09-22-2017, 12:12 PM   #10
I cant say for sure, I dont really know, but I personally haven't heard of any being self lubricating. There may be some out there, I just dont know about them.
If it helps/piece of mind snap a pic of your gears and mechanisms and we/I can say for sure. I have never seen a Micro Lite in person, Im just assuming that it is like my old EVO
Old 09-22-2017, 12:30 PM   #11
Don't let that throw you off, more then likely if you look under the slide when open you will see a tooth bar and a sprocket. That is the lippert Machanical System. That system has to lubricated with a dry lube. If you have the system where you see a metal strip on the two sides, that is a schwintec system, do not lube that one. I hope this helps really didn't mean to throw you off...
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-22-2017, 04:50 PM   #12
benchmarks's Avatar
Thanks for the knowledge. Cheers!
bearings, lionshead, lubricate, slide, tires, wheels
