Old 06-28-2020, 08:34 AM   #1
I have a 2004 Forest River Cardinal Slide out issue
I am looking to post a question about a hydraulic
pump on my Forest River here on the forum. I can not seem to find a way to do that, Please help.
Thanks ecabral
ecabral is offline   Reply With Quote
Old 06-28-2020, 08:50 AM   #2
Hello,
I have a 2004 Forest River Cardinal Slide out issue, The pump is leaking between the resevoir and motor. The reservoir housing is cracked on the outer portion of where the screw goes through to bolt to motor.
It looks like a very small leak but never the less I would like to stop it.
Is it possible to still get the reservoir It says "Haldex" molded into the tank but I can not see any parts or model numbers.
Thank you.
Old 06-28-2020, 09:07 AM   #3
A32Deuce's Avatar
Deleted.
A32Deuce is offline   Reply With Quote
Old 06-28-2020, 09:56 AM   #4
wmtire's Avatar
Threads merged by site team
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 06-28-2020, 01:15 PM   #5
Does it look like this?
Originally Posted by ecabral View Post
Hello,
Thank you.
Slide pump says that it is a HALDEX part no 2201073. Would this be the correct replacement tank and seal? (Lippert 177420 2-Quart Replacement Hydraulic Tank Kit)
Larry
Larry-NC is online now   Reply With Quote
Old 06-28-2020, 01:46 PM   #6
No it does not look like that, Sorry but i wish it did,
No it does not look like that. From the side view it looks octagon in shape and about 10 inches long and about 4 inches in diameter, Is there a way i can post a photo here, I tried copying and paste with no luck....
thanks
Old 06-28-2020, 01:51 PM   #7
You might try draining the tank. Then cleaning the crack area and seal with JB weld epoxy
Harkerr is offline   Reply With Quote
Old 06-28-2020, 02:39 PM   #8
Thank you
Thanks I might have to do that.
Old 06-28-2020, 03:22 PM   #9
Wild gues
thanks
Okay, I admit that was a W-A guess.
To post a photo:
  • Have the file on your computer.
  • At the top of this editor there is a paperclip icon. Click it.
  • A popup will appear, inviting you to select 1-5 images (or other attachments) from your computer. Click the first Choose File button and navigate to the image and select it.
  • Repeat for the next four buttons as needed.
  • Click Upload.
Larry
Old 06-29-2020, 01:48 PM   #10
Photo of my issue, Thanks
cardinal, forest river, slide, slide out
