Old 11-03-2019, 03:53 PM   #1
WoodLark-SC's Avatar
Inside seals keep falling off
Every time we drive down the road, the inside rubber seals at both ends of our slide fall off. We have tried putting them back on, but they just fall off again.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 11-03-2019, 03:59 PM   #2
SeaDog's Avatar
What are you using to hold them in place?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-03-2019, 04:26 PM   #3
Any photos of how they mount?
Every R/V seems to be different.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 11-03-2019, 09:30 PM   #4
I don't have any photos right now, but they slide on to a "track" which runs up the wall beside the slide. They don't always fall completely off, but usually start coming off at the top.
Other than the "track", there does not appear to be anything that holds them in place.
The one towards the rear of the trailer is particularly hard to get back on because it is almost inaccessible.
2019 Rockwood 2503s
Old 11-03-2019, 09:36 PM   #5
Without seeing any photos, I would suggest putting in track and crimpsides of track to hold in. I may be totally wrong !
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 11-03-2019, 09:44 PM   #6
SeaDog's Avatar
use a dab of RTV at both the top and bottom of the seal to hold it in place
Retired Navy
Old 11-03-2019, 10:19 PM   #7
Is it sliding out of the track or pulling out of the track?
Old 11-04-2019, 02:34 PM   #8
There should be a small screw top and bottom at the end of the track and into the rubber. Probably no more than 3/8 to 1/2 in length.
bzac1954 is offline   Reply With Quote
Old 11-04-2019, 03:04 PM   #9
I'm can't say for certain whether it is "sliding" or" pulling" out of the track, but since it seems to start at the top, I'm going to guess pulling.
There is no screw that I can find at either top or bottom.
2019 Rockwood 2503s
Old 11-04-2019, 04:39 PM   #10
It is nothing more than a "Keeper" screw.
Old 11-05-2019, 04:15 PM   #11
I just put the front seal back on. The "track" is basically a "T" shape piece of aluminum with the top of the "T" facing inward. The seal just kind of snaps around the outside of the "T".
There is a wire (slide motor connection) which runs up through the center of the seal. The seal is the only thing that holds this wire in place. The connector at the top has disconnected twice when the seal came off.
There is no evidence that there was ever a screw at the top or bottom to retain the seal.
I think Seadog may have the answer. A couple dabs of RTV (assuming it will stick to whatever kind of rubber the seal is made of) may keep it from coming loose.
I'm not sure what to do about the rear seal since that end of the slide is right up against the refrigerator, and it would take either a Munchkin or a contortionist to get in there (a Munchkin contortionist would be even better ).
2019 Rockwood 2503s
Old 11-07-2019, 05:47 PM   #12
I had similar issues with the horizontal seal above the slide - and I did what bzac1954 stated - I added a screw to one end of the rubber bubble seal. It haven't slid since.
The upright seals already had the screw. I had to re-route the slide motor wires, as the way they were installed, the insulation on the wires would have been chewed thorough on sharp edges.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
seal
