Old 06-30-2020, 06:30 AM   #1
2020 FR Wildwood 263BHXL
JMMP9MM's Avatar
Interior floor buckled
Anyone have this issue. The slide out is messing up the interior floor. Iím not sure if the glue is coming up or the slide roller stretched the floor.
Purchased the 2020 Wildwood in Nov 19í so it will be covered under warranty, but they will have it for a while to fix it. A
ATTACH]232784[/ATTACH]Click image for larger version
JMMP9MM is offline   Reply With Quote
Old 06-30-2020, 06:36 AM   #2
PhD, Common Sense
I donít think this is a glue issue. It appears to me that the flexible material has been stretched and released. This would mean that additional stretching/releasing is likely happening each time the slide moves.
Having watched some RVs being manufactured, Iíd bet no glue was involved in installing the floor covering.
eye95 is offline   Reply With Quote
Old 06-30-2020, 09:10 AM   #3
JMMP9MM's Avatar
Yes, itís freaking annoying. I guess they will need to replace the entire floor as it looks to be one piece vinyl flooring. Most other issues Iíve had with it has been supper minor that Iíve been able to do myself rather than the hassle of taking it to the dealer
floor, led
