Old 06-12-2021, 12:58 AM   #1
Lippert Controller Fault Code Motor 2 Fuse
I have a new 2021 Class C Sunseeker 3050S. Tonight when I was putting the slide out, it moved very briefly and then lost all power.
The fuses in the coach are good, but when we checked the slide out controller, it was giving me 2 green and 8 red flashes...which indicated Motor 2 Fuse. Unfortunately, when I was online with tech support they say to contact Lippert directly for that.
We leave for a month long trip on Sunday so this is less than convenient. Has anyone had a similar issues, and if so, where did you located the Motor 2 fuse?
Pic of controller is attached.
Thank you!
Name:	2021-06-11 20.25.20.jpg
RVHaving is offline   Reply With Quote
Old 06-12-2021, 10:43 AM   #2
Unplug the connectors from the controller and remove the four cover screws and pull the cover off and you see if the fuses are under there. Just match the rating and type to replace them.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
controller, fuse
