Main slide
Have a electric through frame gear slide flush to rv floor.
The white plastic piece that runs lenght of slide i call it the ramp it helps guide it up over the carpet.my question is at one end it seems the ramp taper down the lenght of slide about 3 ft and when i go to close the slide it hits the carpet and stops.I can put a bar in and pry up and get slide to close.I have adjusted the slide before and it worked great.The slide has been in open position probably 6 to 8 month since i last used it.my question is can i shim that plastic peice up or is there anthor adjustment.if i adjust slide then it has other alignment problems.iv checked under slide nothing looks bad main rv floor seams good.
