Old 05-18-2020, 04:31 PM   #1
Main slide creeping out driving
We have a 2015 Cedar Creek 33RL 5th wheel. Our last trip we noticed the main slide moved out while driving about 2 inches. After sucking it back in it eventually crept out again. I see a very small amount oil residue under the pump by the reservoir but really cant see where it maybe coming from.
Anyone else have any ideas what may have started to happen?
Doug Currie is offline   Reply With Quote
Old 05-18-2020, 05:10 PM   #2
I assume it has a hydraulic cylinder that moves the slide? Im not an rv tech but was a Caterpillar hydraulic troubleshooter for years. To me it sounds like your cylinder has an external leak. Either where a line connects or from the packing around the rod. It builds pressure when you suck the slide in but bleeds off due to the leak and the slide moves out.
Biggerfoot is offline   Reply With Quote
Old 06-17-2020, 07:50 PM   #3
Sorry not trying to steal this thread but I’m have same problem with front top of slide on 26fks, anyone with additional thoughts
Csbadvisor is offline   Reply With Quote
Old 06-17-2020, 08:18 PM   #4
Nightshifter's Avatar
I agree with Biggerfoot. If there is no fluid present around the hoses then it is more then likely leaking past the piston inside the cylinder. Then the cylinder has to be replaced. I haven’t seen any that were rebuildable.
2019 Berkshire XLT 45A
2019 Jeep Rubicon JL
Sold prior to buying the Berkshire
2016 Ford F350 Platnium
2017 Heartland Landmark 365
1989 Winnebago Super Chief
Nightshifter is offline   Reply With Quote
Old 06-17-2020, 08:27 PM   #5
Rockinh's Avatar
X2
X2 on hydraulic slides, cant compress oil so it has to be a leak that admits air into the system. That air can also come from a tank being to low or all rams on the level up system being extended to the limits and lowering the oil in the tank far enough to admit air into the system. Check the oil level in the tank when all the slides are retracted and the landing gear are all the way up.
This is only true of hydraulic systems. On electric driven slides, some slide motors have a brake which can fail. The motor works ok to move the slide, but without the brake working, the slide can creep back out, or in.
RockinH Bill
2019 Silverback 37RTH
2014 Shadow LQ 3 horse select
2015 Ram Laramie DRW
2012 concourshttps://www.forestriverforums.com/forums/images/smilies/roflblack.gif
Rockinh is offline   Reply With Quote
slide
