Old 05-13-2013, 08:00 AM   #41
Originally Posted by f1100turbo View Post
you should have a crank in your camper , you stick that in the hole and line it up with nut on the back side and crank away !
This is correct,but on some units when the crank is used it (Bypasses the clutch) which will allow Damage to slide if you crank beyond the (Normal) limits. Youroo!!
