Old 02-18-2020, 01:20 PM   #1
Need to adjust slide
I recently purchased a 2015 Blue Ridge 3025rl, 3 hydraulic Lippert slides. One slide (13' refrig, stove, entertainment) has a 1 1/2" gap at the bottom (both ends) when retracted. The top is flush with the body. When the slide is extended, it is flush all around on the inside. I've cycled the slides in and out a number of times, but no improvement. I see a number of post that sort of addresses the issue, but none with photos or other illustrations. I'm a visual person....I need directions like: loosen "A" and tighten "B" after measuring "C". Any specific directions will be greatly appreciated.
Name:	adj 1 lbl.jpg
ID:	223569   Click image for larger version
Name:	adj 3 lbl.jpg
ID:	223570   Click image for larger version
Name:	adj 4 lbl.jpg
3nails is offline   Reply With Quote
Old 03-02-2020, 08:22 PM   #2
There is some good info here.
https://www.forestriverinc.com
https://dealers.forestriverinc.com
https://lci-support-doc.s3.amazonaws...cd_0001612.pdf
2018 = 26 Days
bayoubraud is offline   Reply With Quote
slide
