Old 02-07-2017, 09:51 PM   #1
Nitro xlr slide out help
Unit is 2 year old, 2016 nitro xlr 305 and when living room slide is all the way out it seals but when I slide it in, the rear bottom is not flush and all 3 other sides are (meaning tops and other bottom.) this Just happened. And I hear a noise about 2 ft from sliding it all way out. Like a pop or slipping of gears, if this makes sense. Please help.
Arkguy29 is offline   Reply With Quote
Old 02-11-2017, 09:21 PM   #2
Well I cut into the underbelly, found the gear and jacked slide up.removed gear and it looks like from the factory someone tried to spot weld in the grove of the teeth to fill a small hole. . I grinding with a drimmel and realigned. Adjusted and no it is god to go.
Old 02-11-2017, 09:30 PM   #3
Arkguy, Glad to hear you resolved your issue. Thx for coming back and letting the forum know what you found even though no one responded to your initial post...
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
dalford is online now   Reply With Quote
slide, slide out, xlr
