Originally Posted by V8s4ever
On my Roo 233S the dinette slide works fine without a battery. Make sure your battery disconnect is connected (and your hot battery lead is taped up or otherwise insulated to avoid a short). The converter should have enough power to do it. On my trailer the slide takes its power from the battery cable, I believe.
On most TT's, mine included, the Slide, Tongue Jack, and Power Awning, are all wired directly to the battery and often connected to the disconnect switch. Each will have it's own inline fuse, usually in a red rubber fuse holder close to it's connection point.
On mine the connections are on the downstream side of the disconnect switch so when switch is off tongue jack, awning, and slide do not work. Thinking it might be someone's idea of an anti-theft measure as the my disconnect switch has a removable "key".
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
